Is Stephen Davis the answer?
Started by RezRob, May 01, 2006, 10:53:04 AM
Quote from: Wingspan on May 01, 2006, 02:19:50 PM
if you're 190lbs, and you run into two guys with a combined weight of 650lbs...i don't care how hard you run, the only place you're going is face first into their armpits and then you're picking turf out of your ass crack
That sounds quite similar to how Chuggie spends his weekends.
As per Davis........I'm gonna have to go with no.  I think at this point he's a bigger name than he is impact player.  With the size the Eagles are going to have on the interior of the o-line now there's no reason what so ever that they should need a "big" back to pound it in there.  A moderately sized runningback should suffice nicely.
